en respuesta a: pendean
I have the same problem the same with my Lenovo Yoga 720 and Active Pen 2. Thank you for reporting the issue here as I was going insane trying to figure out what was causing it. I thought the pen or screen digitizer was faulty but that was a silly conclusion as they worked perfectly elsewhere.
I uninstalled Autocad 2019 and installed 2017. Everything is working now so I will use that version. Thanks again :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
