pendean
en respuesta a: Anonymous
Did you just jump into TABLE command without setting the style you wanted first?
Did you actually go into TABLESTYLE command and define what size your cells and text need to be? That needs to be done first my friend.
Do you have the correctly set text styles defined in STYLE command? Also required before you get into defining the table style you want to use.
Let us know if this is your first time using tables in AutoCAD too.
