- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
size problem with multi- lines and tables
I have a problem with the tables\ multi-lines in AutoCAD, every time I try to insert a table or multi-line it ends up looking huge even when I try to scale it. I checked the units and scale and they look fine I uninstalled the app and re-download it and the problem still exist. I am using 2019 AutoCAD version the box next to the table is 5x5 meters and the table ended up as 36x15.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am not sure what you mean by multi-lines because that is actually a feature in AutoCAD. Regardless, if your tables come in a strange size, you might check the text style and height that is assigned. You might also try creating the table in paperspace to see if that helps.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Did you actually go into TABLESTYLE command and define what size your cells and text need to be? That needs to be done first my friend.
Do you have the correctly set text styles defined in STYLE command? Also required before you get into defining the table style you want to use.
Let us know if this is your first time using tables in AutoCAD too.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved. If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
