TerryDotson
en respuesta a: Anonymous
One thing you could try (on a COPY of the drawing).
  1. List Command, enter L for Last.  Look at the coordinates to see if they look valid for your project.  If not use some method to determine where your good geometry should be.
  2. Zoom Command, enter C for Center.  Enter the X,Y coordinates of where your good geometry should be, followed by a reasonable zoom factor, like 10, 100, etc.
  3. Use the mouse wheel to scroll out until the extents of your good geometry shows.
  4. Erase Command, enter All, then R for Remove, window off your good geometry.
You should then be able to zoom extents.
