501 Vistas, 2 Respuestas
Modelspace limit exceed.
The drawing was not geeing displayed and it was showing an error of Modelspace exceeded. If we zoom to extent it was getting hanged. Pic attached for ref.
imadHabash
en respuesta a: Anonymous
can we take a look to your drawing ? please ... if you're using AutoCAD 2018 or later change format type to your sample from SAVE AS command then upload it here .
Imad Habash
TerryDotson
One thing you could try (on a COPY of the drawing).
  1. List Command, enter L for Last.  Look at the coordinates to see if they look valid for your project.  If not use some method to determine where your good geometry should be.
  2. Zoom Command, enter C for Center.  Enter the X,Y coordinates of where your good geometry should be, followed by a reasonable zoom factor, like 10, 100, etc.
  3. Use the mouse wheel to scroll out until the extents of your good geometry shows.
  4. Erase Command, enter All, then R for Remove, window off your good geometry.
You should then be able to zoom extents.
