pendean
en respuesta a: Anonymous
the error message is quite specific: you have the wrong version pdf drivers installed. While workarounds are nice, it'snot the cure.
RESET AutoCAD to remove old drivers you have as a result of using the Migration function from an older AutoCAD variant.
Or Repair/Reinstall your AutoCAD version.
Either way backup your customizations first just in case you've not been diligent about storing them to easily recover manually.
