3160 Vistas, 12 Respuestas
Publish multiple layouts/drawings to single pdf
Hello All,
I am having problem with Output - publish to pdf. I attempt to publish (batch) a collection of drawings or layouts, in the publish dialog box, i select the "PDF" option in the "Publish to" drop-down list, i instantly get this error message:
"The plotter configuration cannot be used for one of these reason: the preset cannot be found, the driver cannot be found, or the driver has a problem."
Also, "Publish Options" is greyed out.  We have this problem when we upgrade to AutoCAD 2017.
Please share if you have a solution. Thanks in advance!
Dennis
