3161 Vistas, 12 Respuestas
Publish multiple layouts/drawings to single pdf
Hello All,
I am having problem with Output - publish to pdf. I attempt to publish (batch) a collection of drawings or layouts, in the publish dialog box, i select the "PDF" option in the "Publish to" drop-down list, i instantly get this error message:
"The plotter configuration cannot be used for one of these reason: the preset cannot be found, the driver cannot be found, or the driver has a problem."
Also, "Publish Options" is greyed out.  We have this problem when we upgrade to AutoCAD 2017.
Please share if you have a solution. Thanks in advance!
Dennis
imadHabash
en respuesta a: Anonymous
while upgrading your AutoCAD 2017 , did you transfer any settings from previous CAD version ? if the answer is yes .. then i suggest to reset AutoCAD to default settings . >> Click <<
Imad Habash
john.vellek
Hi @Anonymous,
I suggest that you use the Plotter Named in Page Setup instead of PDF. This allows you to use the existing page setup that has been applied to a layout or to import one. This should give you much more control over how the drawings get plotted to PDF.
John Vellek
en respuesta a: john.vellek
Thank you John!
But if using Plotter named in page setup, the pdf will be coming out separately. I would like to publish these drawings to a SINGLE pdf, instead of multiple pdf for multiple drawings.
Also, Publish Options is not available in Plotter named in page setup. It only available to choose "Single sheet file" if PFD is selected.
john.vellek
Hi @Anonymous,
Actually, using the method I suggested can still result in a single multi-page PDF.
John Vellek
Hi John,
For me, the drawings came out individual pdf file per drawing, not a single pdf with multiple pages. Can you do screen shots of what you did in order to get a single multi-pages pdf?
john.vellek
 Hi @Anonymous,
Try setting PUBLISHCOLLATE=1 to see if that helps.
John Vellek
imadHabash
you may need to check PUBLISHCOLLATE system variable , and it's recommended to restart your AutoCAD .
Command: PUBLISHCOLLATE
Enter new value for PUBLISHCOLLATE <1>:
Imad Habash
Hi, I changed  PUBLISHCOLLATE=1 and restart AutoCAD. They still came out individual pdf. ???
pendean
the error message is quite specific: you have the wrong version pdf drivers installed. While workarounds are nice, it'snot the cure.
RESET AutoCAD to remove old drivers you have as a result of using the Migration function from an older AutoCAD variant.
Or Repair/Reinstall your AutoCAD version.
Either way backup your customizations first just in case you've not been diligent about storing them to easily recover manually.
jayhar
Try this https://knowledge.autodesk.com/profile/O37DG462CCE599DA?_ga=2.51762346.269078099.1532317144-81599467...
Visit this profile CONTRIBUTIONS > LINKS > AutoCAD Auto Publishing DWG to PDF
OR
Direct visit Youtube....
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
en respuesta a: jayhar
Thank you!
I tried everything you tauch, but for some reasons, the pdf are still coming out individually! And BTW, with version 2017, publish to pdf is different with previous version.
Last thing i will try today is to repair/reinstall my AutoCAD.
Is there anything else i have missing?
john.vellek
Hi @Anonymous,
It sounds as if your DWG to PDF  is damaged.  I have attached mine from AutoCAD 2017.  It should be placed in a location similar to this one:
C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters
John Vellek
