296 Vistas, 2 Respuestas
MIRROR
WHEN I USED TO MIRROR AN OBJECT A POP UP WOULD APPEAR AND ASK IF I WANTED TO DELETE THE ORIGINAL NOW THE POP UP DOES NOT APPEAR.
imadHabash
en respuesta a: Anonymous
EXPERT (System Variable)  >>Click << control prompts for some commands BUT not for mirror command . you can avoid Y , N while using mirror command by writing simple code that serve your issue .
Imad Habash
andkal
Try setting DYNPROMPT (system variable) from 0 to 1
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
