343 Vistas, 3 Respuestas
Pdf is plotting offset
I have a dwt template that I need to save as a dwg. When I save the dwg as a pdf or plot, the first page is centered, but the rest of the pages are offset to the lower right corner.
I have purged everything in the template and detached all xrefs.
pendean
en respuesta a: Anonymous
Post your dwg file that is ready to plot, lets all see your settings for everything.
john.vellek
Hi @Anonymous,
Do you utilize a page setup with your drawings? That is frequently the quick fix for such behavior.  If you can share your file(s) and show me how you set up and produce your plots, I am happy to see if I can help.
John Vellek
john.vellek
Hi @Anonymous
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
