cadffm
en respuesta a: strictlyvintagesurf
The right way is to attach the image with relative path (or non, if the image is in tge same folder). Send your DWG and the imagefile.
The perfect way: Use command etransmit for all external stuff like fonts images other xrefs plotstyletable..
The only way to paste an image as content to dwg is to insert it as embedded OLE object.
But i not prefer to merge raster data with your well vector datas in your dwg.
So: Attached img bind directly is not possible.
Sebastian
