ishmaela8
en respuesta a: ennujozlagam
Well I was actually referring to using the layout of the first drawing sheet as a template and using it for the other supporting drawings of the same job. Then a local pro told me to right click on the layout tab then go on move or copy, then- press move to end, then create a copy. So in this way you can get new pages with the same sheet layout- which you can rename appropriately.
