256 Vistas, 2 Respuestas
Small problem..Can someone give a little tweak to 'length' asked on my lisp file
Can someone edit the lisp in such a way that when "Enter the width of door" is asked it must automatically subtract 4 inches from my input value...For eg;when I input the  Width of door as 4ft then the lisp must subtract 4inch automatically and enter the final input as 3ft8inch"
Thanks in Advance!
leeminardi
en respuesta a: Anonymous
Your current code has:
  (setq W (getdist "\nEnter Width of Door <3.0'>:  "))
  (if (= W nil)
    (setq W 36)
  (setq W (+ W 4))
If you remove the line:
(setq W (+ W 4))
W will be 4 inches less  as this line adds 4 to W. .
What value do you want if no value is given?  Currently it is 40 (36 +4).  If you want it to be 40 and you remove the line (setq W ( + W 4)) then change the line
(setq W 36)
 to
(setq W 40)
lee.minardi
en respuesta a: leeminardi
WOW...WORKED AS EXPECTED..
THANK YOU SIR! GOD BLESS YOU!
