- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
To Create the Page Setups:
1, Right-click the Model tab (lower left) and choose Page Setup Manager...
2, Click New... to create a new Page Setup. Name your first sheet.
3, After you set up the first Page Setup, you can select it to Start With when you create more.
4, Adjust the paper size, PDF plotter, plot style table, etc. to suit your needs.
5, Make sure What to Plot is set to Window.
6, To the right of that, click the Window< button and draw a window around what you want to plot on that sheet.
7, Back in the dialog box, click OK.
8, Repeat the same process for each sheet you want to plot, creating a Page Setup for each one.
To Save the Sheet List and Batch Plot:
1, Save your drawing.
2, Click the Application icon (top left) > Print > Batch Plot.
3, Choose Plotter named in page setup.
4, Rename the <DrawingName> Drawing-Model sheet to your first sheet name.
5, Then select the corresponding Page Setup from the Page Setup dropdown list.
6, Right-click the sheet name and choose Copy Selected Sheets.
7, Rename the new sheet and pick the corresponding Page Setup from the dropdown.
8, Repeat until all your sheets are added.
9, Then at the top, click the Save icon to the right of the Sheet List dropdown.
10, Save the DSD file. (You can pick this to select the same sheet list you just created whenever you publish again in the future.)
11, Publish.
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
