Kent1Cooper
en respuesta a: gotphish001
@gotphish001 wrote:
Open a blank drawing, draw what you want the block to be, use BLOCK command to make what you drew a block, save drawing and your done. ….
I would suggest you not  use the BLOCK command to make what you drew a Block inside the drawing file -- if you do, when someone downloads and INSERTs that drawing, it will become a Block with another  Block nested inside it unnecessarily.  Just leave what you drew as a .dwg file, and it will become a [non-nested] Block definition when INSERTed into another drawing.  BUT do  absolutely use the BASE command  in that drawing, to define the location in the drawing that will become the insertion base point when someone uses it in an INSERT command.
Kent Cooper, AIA
