ArchD
en respuesta a: Anonymous
If you can get some GPS data points in world coordinate format (typically a property boundary break points), 2 at the least, you should be able to import them into your drawing and move/rotate/scale your design on the two known locations.
Unfortunately, you are using an Apple OS, which does not support Civil 3D. If you were on Windows you could look into getting Civil 3D and many more options open up including coordinate systems that you can use that will allow for easy lat/long conversion that helps out in the field.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
