jayhar
en respuesta a: Anonymous
This behavior of the software might be because of one of the following reasons :-
1). You might be making use of and calling a function from the previous version of AutoCAD. You need to make sure that all the functions you are calling in your projects are available with the version of AutoCAD you are using.
2). The other reason might be the lack of enough virtual memory. To fix this –
  • Right click ‘My Computer’ and select Properties.
  • Click -> Advanced -> Performance -> Settings
  • Click -> Advanced -> Virtual memory -> Change
  • Set initial and maximum size to 4096
  • Click -> OK
  • Restart your system.
  • Done.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
