491 Vistas, 2 Respuestas
AUTOCAD APPLICATION CANNOT CONTINUE
I use autocad 2018 after i launch the application, the dwg file is opened, and just after afew minutes from then autocad shuts down saying äutocad  cannot continue, please save the data for recovery etc." . I have tried repairing and reinstalling the software, unfortunately nothing worked. please help me with this problem
Alfred.NESWADBA
en respuesta a: Anonymous
seeing the filename with
recover_recover_recover_recover .....
I guess your AutoCAD file already has a lot of issues. Please load your drawing using command _RECOVER (instead of _OPEN), then start a new drawing parallel to this existing one and use copy & paste to transfer the existing geometry into a new drawing.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jayhar
This behavior of the software might be because of one of the following reasons :-
1). You might be making use of and calling a function from the previous version of AutoCAD. You need to make sure that all the functions you are calling in your projects are available with the version of AutoCAD you are using.
2). The other reason might be the lack of enough virtual memory. To fix this –
  • Right click ‘My Computer’ and select Properties.
  • Click -> Advanced -> Performance -> Settings
  • Click -> Advanced -> Virtual memory -> Change
  • Set initial and maximum size to 4096
  • Click -> OK
  • Restart your system.
  • Done.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
