ennujozlagam
en respuesta a: 1017ligar
hello, are you in paperspace? go to modelspace and paste it or it could the drawing you want to paste have the same block name> go to command promt type RENAMe and raname those blocks. and check if they are in the same UCS. and see if helps. thanks
