neaton
en respuesta a: Anonymous
You can print an unsaved file if you don't create a .dsd. file. The .dsd file is created when you choose Yes to save the current list of sheets in the Batch Print/Publish command. Only save the sheet list if you want to plot the same files, with the same layouts exactly the same way more than once.
When the Publish - Save Sheet List dialog opens choose No to not save a .dsd file. If you will never use .dsd files highlight No then check the box Always perform my current choice and hit Enter. You can turn it back on from Options, System tab, Hidden Message Settings.
From your snip you haven't chosen a Page Setup to print from.
Nancy
