- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am trying to create an engineering drawing for a 3D part. In order to dimension and label properly, I need to show appropriate details and sections. I am trying to figure out how to create sections within the layout tabs. The two photos below show what I am trying to achieve.
I tried to do this using a section plane inside model space, creating a block and inserting it into my layouts tab. However the scale was off and when I tried to fix it, it didn't work. I also tried to use the section button inside the layout tabs (that is after using the view--->base--->from model space and adding in the top and ISO view of my model). That did not work either.
Is it possible to create sections within the layout tabs and then be able to dimension them. In addition, in the picture above, there is a dual section (section A). I am also having a hard time figuring out how that was put in.
Thank you.
¡Resuelto! Ir a solución.
