- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Good night, I would like to learn how to open a saved drawing template as a new layout?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> I would like to learn how to open a saved drawing template as a new layout? <<
your question still need more and more to understand what you need . maybe SAVE AS command will help or Ctrl+N will help to use a new template files . please try to describe more your issue ?
Regards, ![]()
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hello, you can saveas > .DWT. please describe more as mentioned above. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Perfect is with attdefs..
Saveas dwg
You can INSERT the dwg AS Block. Command Insert[Browse]
But a real Layout as Template:
Create your Layout(Layout tab) save as dwg or dwt.
Import this Layout by Designcenter or command Layout, option template.
Perfect for new drawings too:
Create a file with your styles, Layers and Layout.
Saveas dwt.
Set QNEW to this file and start a new file by QNEW
(Or NEW, and select this dwt)
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Either right click on a layout tab and choose "From template" or use the LAYOUT Template command.
Right click layout tab menu
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Well I was actually referring to using the layout of the first drawing sheet as a template and using it for the other supporting drawings of the same job. Then a local pro told me to right click on the layout tab then go on move or copy, then- press move to end, then create a copy. So in this way you can get new pages with the same sheet layout- which you can rename appropriately.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi pro, can you direct me to or send me some free window blocks in elevation.
Email is ishmaela8@gmail.com
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
