1232 Vistas, 6 Respuestas
AutoCAD Batch Plot text prints light
I have recently shifted AutoCAD 2015 to AutoCAD 2017. When I am batch plotting my project the text comes out very light which we can barely see. I have been trying to solve this issue but wasnt able to find the solution. Any help would be greatly appreciated.
My batch plot settings are:
Plot Style: FineMono.ctb
Shaded Viewport options:
     Shade Plot: As Displayed
     Quality: Normal
Printer/Plotter: DWG To PDF.pc3
Plot Area: Window
Landscape
@Anonymous, john.vellek has edited your subject line for clarity: Batch Plot text issue
cadffm
en respuesta a: Anonymous
Only by command publish or even command plot?
Sebastian
en respuesta a: cadffm
Only by publish when I am batch plotting, But when I am individually plotting it, the print comes just fine.
pendean
See your other duplicate post as well for replies...
Are you using the exact same PAGESETUP in Publish that you are using in PLOT command? Most likely the issue based on your posts.
en respuesta a: pendean
Yes I am using the same settings
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Can you share a sample drawing(s) that have this problem when using PUBLISH?  I would like to take a look at how this is working on my side in order to make some suggestions.
Please make sure that when you use PUBLISH, that you use the Plotter named in Setup option and then verify that you have applied your Page Setup.
John Vellek
chriscowgill7373
I have not heard of AutoCAD doing something like this in the past when using the same page setup.  However I have heard of AutoCAD Electrical doing this, as there are some separate settings for publish vs plot:
https://knowledge.autodesk.com/support/autocad-electrical/troubleshooting/caas/sfdcarticles/sfdcarti...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
