291 Vistas, 3 Respuestas
AUTOCAD choosing printer to use base on paper size
Thank you all for taking the time to read this. In my office I have several printers that print 8-1/2"x11", one of which is my default printer in windows. I also have a printer configured to only print 11"x17" and a plotter which will print B,C and D sizes.
8/10 times I print to the default windows printer option under "Printer/plotter" in the Plot Dialog box. When I want to print to 11"x17" I have to chose a different printer and the paper size. Is there anyway to make a pc3 file for a certain printer to print out a paper size each time? Say I want 3 different printer pc3 files for my plotter, depending on which paper size I want utilized without having the change the paper size and only the printer.
I am using Autocad 2018, recently upgrading from LT2019 after years of 2014LT.
dmfrazier
en respuesta a: Anonymous
Of course! This is one of the primary reasons that PC3 files exist. Once you've created the PC3 file (giving it a name that gives you a hint about the printer name and the page size, perhaps), then you must select that PC3 file when you run the plot.
en respuesta a: dmfrazier
Different from page setup?
dmfrazier
Yes, but related.
A page setup includes a reference to a printer, directly, or indirectly, via a PC3.
