cadffm
en respuesta a: dbaldzhiev
So does the file work in AutoCAD once the layouts were set current?
So it's the point i said, okay.
Sorry, I know nothing about possible structures and working methods in Revit and export.
Based on my knowledge from AutoCAD:
Was the Layout ever current in Revit?  If this description makes any sense for Revit at all.
Or:
Are the files "good.dwg" and "issue.dwg" exported in the same way with the same setting?
Compare the Settings for Layout/Plot and Export on Revits side.
I hope you find a Revit supporter, unfortunately I can not contribute anything.
Sebastian
