GrantsPirate
en respuesta a: ema.drnda02
If using the Ribbon then the choice to save the changes is in the upper right hand side.  You can also hit the right mouse button and pick the option there.  Finally you can use the REFCLOSE command at the command line to type that in.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
