ema.drnda02
339 Vistas, 4 Respuestas
xrefs
Here it goes amazing AutoCad comunity.
The office upgraded a wek ago to AutoCad 2019. I noticed some changes but what I am most irritaded and confused by is the following.
e worka lot with XREFS and usually if I double click on an xrefs and make a small change (for instance move something) I simply click on the safe ad close button for xrefs and my drawing has updated onto its original file,
However, I am curently nor able to safe nor excit my xref once in it because there is no option to sefe an exit. Nor can I safe and exit my original drawing.
Please, help is needed.
cadffm
en respuesta a: ema.drnda02
Bitte keine CrossPosts, das erzeugt unnötig arbeit und ist oft auch hinderlich in der Lösungsfindung.
https://forums.autodesk.com/t5/autocad-produktfamilie-deutsch/xrefs/m-p/8074489#M9805
Sebastian
RobDraw
Could you show us some screen shots so that we can fully understand your question?
Rob
chriscowgill7373
Can you confirm that you installed 2019.0.1?  Is there a reason you cannot use XOPEN instead of REFEDIT (if the update didnt fix this issue)?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
GrantsPirate
If using the Ribbon then the choice to save the changes is in the upper right hand side.  You can also hit the right mouse button and pick the option there.  Finally you can use the REFCLOSE command at the command line to type that in.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
