dc
en respuesta a: Ajilal.Vijayan
Thank you Vijayan!
I tried your solution and it works well. I am now learning much more about fields and of course want to push the automation as far as I can.
Now within your example, is it possible to make a field that acquires a value from another block attribute, based on the location of the blocks insertion point relative to a boundary of the "host" block? Please see attached dwg file illustrating this.
These drawings will all be 2d. There will never be an overlap between one "host" and another.
Wondering if this could be accomplished with a Diesel expression inside the field?
