06-14-2018
03:59 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-14-2018
03:59 AM
Lisp not working in AutoCAD 2018
Is there any solution to convert the existing lisp files created in lower versions of AutoCAD to make them compatible with the latest versions (AutoCAD 2018).
06-14-2018
04:11 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-14-2018
04:11 AM
It is depent of the content of the files, millions works in 2018 without a change,
but if some functions commands or System variables has changed since, then you have
to edit the code (if source code is present).
Very popular is command vs. command-s issue
Which is your the newest version where the tools running fine?
A sample file would be helpful for helping you.
Sebastian
06-14-2018
04:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-14-2018
04:35 AM
The vast majority of LISPs will work in newer versions. If you are having a problem with a particular one, you might want to post your question in the LISP forum.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Rob
