john.vellek
en respuesta a: nggarnaud
Hi @nggarnaud,
What changed in your environment in the last day that might have caused this?  Did you change some drivers or security settings? Perhaps a Windows update? I suggest checking for some of these things. If you can undo what has changed then you will likely be up and running.
You might also check for a new graphics driver. Sometimes after an update gets applied, drivers need to be updated as well.
John Vellek
