ergoarchitecture
en respuesta a: leeminardi
Thanks Lee!  That is very encouraging!
I tried to install TrueView but after downloading and a 20 minute install process it finally gave up and said that it failed to install properly.   In the meantime, someone from Lumion sent along a Mass Element in ACAD 2013 format.  It inserted fine, and retained its object properties until we tried to copy or array it.  The children were plain old 3D Solids!
Your post gives me hope that we can define it as a block and as long as we merely insert it repeatedly, it should remain a Mass Element.  That would suit our needs fine!
Thanks for the help!  I will report back once we have sorted it all out and found a viable workflow as I am sure we are not the only ones with this problem!
Steve
