en respuesta a: imadHabash
Thanks for the response! The problem is that when you press any button does not work command! I want to log in, too, do not click, I want to see whether you need to update the autocad?! What if you need to install updates??? So the program does not work, if you open it does not close it - because it does not respond to the button press. By the way, RUSSIAN is there, thank you for your understanding.
