gotphish001
en respuesta a: Anonymous
If zoom extents doesn't work as suggested maybe you added something way off to one side by accident. After you do a zoom extents, press Control + A. That will select everything on the screen. Do you see any blue grips? If you see a bunch on one side of the screen and a couple on the opposite side then one of those is something you probably put there by accident. Zoom in to one of them and see if it's your project. If it's something you don't need then delete it and zoom extents again. Make sure you unselect everything with ESC and then reselect the things to delete. You don't want to control+A and then delete and erase everything by accident either.
Nick DiPietro
Cad Manager/Monkey
