06-10-2018
12:25 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-10-2018
12:25 PM
try VISRETAIN system variable from command line , and from OPTIONS dialog ( Open and Save tab ) you will find it there . >> Click >>
Edit : The option to Retain changes to Xref layers (VISRETAIN system variable) has moved from the Options dialog box (Open and Save tab) to the Layer Settings dialog box. also you have to check VISRETAINMODE (System Variable) that Controls the behavior of the VISRETAIN system variable when it's set to 1.
Imad Habash
