407 Vistas, 4 Respuestas
AUTOCAD 2017 not working correctly
Autocad 2017 i s having intermittent problems with drawings lines, trim, and many other functions.
I have unistalled the program and re installed it but it is still having problems
imadHabash
en respuesta a: Anonymous
Hi and welcome to AutoCAD Forum,
>> Autocad 2017 i s having intermittent problems with drawings lines, trim, and many other functions. <<
still we need more specific details regarding your issue please ?
  • Does this problems happened in every drawing or just in a certain one ?
  • Try AUDIT and Purge (Regapps ) commands and see if any changes .
  • Installing latest updates and service packs . >> Click <<
If not fixed ... please get back and describe more your issue .
Imad Habash
boubami
Most of the time, these problems are due to the version of AutoCAD and the version of Window you are using in your computer or if you already have or had a fake AutoCAD licence installed on your computer.
1- Fake license:
Uninstall that fake licence software from your computer with all files that come with it. Restart your computer and install the good software again.
2- Versions:
Make sure you have Window 10 greatly installed on your computer and install AutoCAD from Autodesk site. Get it activated with a licence number from Autodesk.
3- Please, if your computer is slow, do not request him to do several thing at once. You should let it take some time before opening a programm or it will freeze or shut down.
Please let us know if this worked so we can keep finding solution for you.
Regards
john.vellek
Hi @Anonymous,
It sounds, from your description and the attached image you provided, that you feel that your computer is working excessively which prohibits normal operation in AutoCAD.
I suggest first verifying that your AutoCAD is fully up-to-date using your Autodesk Desktop App or through  your account page.
If the problem persists, Please use Task Manager  shows many Chromium Host Processes running concurrently. Try ending these to see if AutoCAD performance returns to normal.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
