imadHabash
en respuesta a: Anonymous
>> .... but it did not open and only comes a black screen  <<
if you confirm that you already save your drawing with a special name . then the problem is where is your CAD elements ? please make sure that you open the right CAD drawing and from the right folder . if you're certainly sure try after opening to  ZOOM >> Extents  and see if any objects appeared . also yo can take a copy from the .Bak file for the same drawing and rename the extension .Bak to .Dwg .
Imad Habash
