ara_neresesian
en respuesta a: guymlink
Hi
i think you can use select similar then send selected same objects to back or bring to forward.
just select one object then right click select similar (by the way you can adjust selecting rule  layer,linetype    ,......
and also you can use filter and quick select .
if you need more info just upload a simple file and explain what you want maybe we can find faster way.
but the select similar is perfect tools try it.
good luck.
