Kent1Cooper
en respuesta a: guymlink
@guymlink wrote:
is there a way to set a line type to have a permanent display order? like making a hatch linetype always appear under everything?
It would be easy to make a routine that would find everything of a specified linetype and move all to the back.  That would be easiest if everything with that linetype has it assigned as an override, but it could also be made to find things on Layers  with that linetype that don't  have a linetype override.  Does that sound workable?
But I'm not sure I'm understanding what you really want -- I've never heard of a "hatch linetype," and Hatch patterns can be set to not  use a non-continuous linetype if their Layer has one.  And none of it would apply if you're talking about Hatch background shading, or SOLID-pattern Hatching, which seems to be what some suggestions here are really about, rather than linetype  specifically.
Kent Cooper, AIA
