- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Thanks @Alfred.NESWADBA,
I was just wondering how these paths were added. Unless I've lost my mind (which is not out of the realm of possibility) I did not add these paths by any means. I ran across them as I was trying to solve an issue in C3D 2019 with drawing load and plot/publish times being exponentially longer than they had been in C3D 2017.
The cause of that problem turned out to be my long used custom .cui that C3D 2019 does not appear to like. It may have gotten corrupted, idk. I created a new one and transferred things I still use and left out old things and solved the problem. Some "old things" are from way back, R10-R14 popup menus that have been carried along since I first converted my .mnu to a .cui (Even though Autodesk dropped Popup menus from being customizable, I found that they would translate to .cui and you could still call them if you changed the tag from ***<name> to **<name> in the .mnu file... if my memory serves me well.)
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
