- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Does AutoCAD automatically add trusted locations if you allow something (.lsp, .scr, etc.) to be "always load"ed from any folder?
I have project folders where I do not have lisp files to load that are in my "Trusted Locations" and I'm sure that I did not add them explicitly. (They are all of the l:\* except l:\Util\...)
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No, AutoCAD does not add paths automatically after it was first initialized (some paths are needed to have Civil 3D working, but these are set at the first start of Civil 3D/AutoCAD).
But it's not so hard as developer to add these paths, so if the tools you allowed to start once, do have such code (to add the tools folder to trusted paths) then these tools might have added these paths.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks @Alfred.NESWADBA,
I was just wondering how these paths were added. Unless I've lost my mind (which is not out of the realm of possibility) I did not add these paths by any means. I ran across them as I was trying to solve an issue in C3D 2019 with drawing load and plot/publish times being exponentially longer than they had been in C3D 2017.
The cause of that problem turned out to be my long used custom .cui that C3D 2019 does not appear to like. It may have gotten corrupted, idk. I created a new one and transferred things I still use and left out old things and solved the problem. Some "old things" are from way back, R10-R14 popup menus that have been carried along since I first converted my .mnu to a .cui (Even though Autodesk dropped Popup menus from being customizable, I found that they would translate to .cui and you could still call them if you changed the tag from ***<name> to **<name> in the .mnu file... if my memory serves me well.)
