06-05-2018
11:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-05-2018
11:57 AM
After specifying the base point you can type
'cal [ENter]
and then type in an equation.
For example, the following sequence will scale an object up by Fibonacci's ratio.
Command: SCALE Select objects: 1 found Select objects: Specify base point: Specify scale factor or [Copy/Reference]: 'cal >>>> Expression: (0.5 + 1.25^0.5) Resuming SCALE command. Specify scale factor or [Copy/Reference]: 1.6180339887499
lee.minardi
