- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When using the touchscreen to input lines, I am having two crosshairs on screen. One at the proper location I am touching the screen, and another about 3 cms beneath. This double input provides an unexpected behavior on most commands. The offset distance and relation between the point I am touching, and the second crosshair is always the same. When drawing a polyline and clicking multiple points along an horizontal line, without using the snap function, I get a sawlike profile. When using a mouse or the touchpad, behavior is as expected. I am using a surface pro tablet with normal Autocad. I know it is not homologated hardware for Autocad, and I should expect performance issues, but the behavior should be normal. Thanks. Beneath you can see an example of what multiple points along an horizontal line acomplish.
¡Resuelto! Ir a solución.
