- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When using the touchscreen to input lines, I am having two crosshairs on screen. One at the proper location I am touching the screen, and another about 3 cms beneath. This double input provides an unexpected behavior on most commands. The offset distance and relation between the point I am touching, and the second crosshair is always the same. When drawing a polyline and clicking multiple points along an horizontal line, without using the snap function, I get a sawlike profile. When using a mouse or the touchpad, behavior is as expected. I am using a surface pro tablet with normal Autocad. I know it is not homologated hardware for Autocad, and I should expect performance issues, but the behavior should be normal. Thanks. Beneath you can see an example of what multiple points along an horizontal line acomplish.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am having the same problem with my surface. MY surface pen does the same thing.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I haven't ever had access to a Surface Pro so I am resorting to some Internet searches. Have you tried using the Calibration utility inthe Windows Control Panel?
What happens in other graphics programs such as Paint 3D?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for your prompt response. The offset I am experiencing happens only
in the drawing area. The cursor works very precisely in all other areas of
the program, as well as in other programs like paint 3d.
I know the surface is not certified for use in autocad, and because of
that, I was expecting to have certain limitations in use, but this is
obviously a glitch.
I tried the screencalibration, but the problem remains.
Regards.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
AutoCAD for Windows is not a true mobile app and the Surface Pen combo has yet to be certified: since you cannot replicate the problem with a mouse or the touchpad it may have to be something you wait for Autodesk to acknowledge the Pen and certify its use.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have the same problem the same with my Lenovo Yoga 720 and Active Pen 2. Thank you for reporting the issue here as I was going insane trying to figure out what was causing it. I thought the pen or screen digitizer was faulty but that was a silly conclusion as they worked perfectly elsewhere.
I uninstalled Autocad 2019 and installed 2017. Everything is working now so I will use that version. Thanks again ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes, it was a glitch with 2019.0.1. I tried Autocad 2017 and it worked fine, and now that version 2019.1 is out, it also works like a charm. Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
