05-27-2018
07:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-27-2018
07:34 AM
I opened your dwg
a new layer current and BOUNDARY, click inside your work and the boundary is made indicating all your work is on one plane.
UNDO that
I find two polylines and two arcs, no splines
JOIN joined and converted into one closed spline
are you asking about the Normal Z of negative value in properties? some explanation in these posts.
https://forums.autodesk.com/t5/autocad-map-3d-forum/normal-z/td-p/636762
https://forums.autodesk.com/t5/autocad-forum/normal-z/td-p/6484069
dave
