john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 It sounds like you have a mixture of older software in this environment.  Because of the server version, I assume that the storage is likely some sort of RAID in the server itself and not an external store such as NAS or SAN.
I would first use your RAID utility ti verify that the assembly is working properly and that no portion of the RAID has errors.
Then, I would construct a new File share with full permissions.  Manually map a drive to this share on the client side. Copy a CAD project there and see if you are still seeing errors.
What is the operating system on the client side?
John Vellek
