- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am having an issue with the FilletEdge command. Instead of smoothing the base of the circular extrusion, it creates the exact opposite.
john.vellek has embedded your image(s) for clarity
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @avi.pirlog,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Are you trying to soften the top edge?
Can you share your model so I can take a look? What kind of radius do you want to apply?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The fillet will work as expected if that is one solid, if the base and the cylinder are not unioned together you will get unexpected results.
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you so much for the help!
@GrantsPirate wrote:The fillet will work as expected if that is one solid, if the base and the cylinder are not unioned together you will get unexpected results.
