307 Vistas, 2 Respuestas
Adding new attributes to exisint block with multiple parameters
I've added a new attribute to a block that has multiple paramters in it.  (Move, Rotate)
The attribute currently comes out at the bottom of the attribute edit box upon insert, but I want it moved up in the list.  I use the BATTMAN function, but it doesn't seem to save when I save the block dwg.  I can't redo a WBLOCK because it's not enabled with the paramter states visible.  How do I simply move this attribute up my list in the block?
