814 Vistas, 3 Respuestas
Connecting to Enterprise GIS Data
Hello all,
I'm wondering if any one can point me to the recommended way to connect to an Enterprise GIS database using AutoCAD. We have a SQL database enabled as an enterprise geodatabase (SDE) through esri's ArcGIS technology.
Specs
SQL 2014
ArcGIS (any version) We can go back as far as 10.3.1
AutoCAD 2017
Using the Data panel, we are having zero luck connecting either with an Add ArcGIS or add ArcSDE connection. Both appear to want you to make the connection with an SDE service, which hasn't been supported by esri sinse ArcGIS version 10.2. We have had luck using a SQL Server Spatial Connection, but I'm unclear as to why the other connection types wouldn't work. I'm struggling to understand what the recommended approach is for more modern versions of ArcGIS enabled databases. Is anyone connecting to these types of databases and can share a recommended approach?
Thanks you,
