1840 Vistas, 4 Respuestas
Creating an Area using Rectangle command
Quite familiar with Creating a rectangle/square using the Rectangle command.
There is also an option to create a rectangle by area. fantastic, just what I need. So, follow the prompts and i get nothing like what I hoped for.
command list below.
Command: _rectang
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]:
Specify other corner point or [Area/Dimensions/Rotation]: A
Enter area of rectangle in current units <9000.000>:
Calculate rectangle dimensions based on [Length/Width] <Length>: L
Enter rectangle length <3.000>: 3000
I end up getting a rectangle, not a square.
I have attached .dwg which I hope shows what i want to achieve better than my description.
