409 Vistas, 7 Respuestas
Block Properties in .dwg file
I am trying to modify (update) a .dwg file, by replacing a couple of "blocks" that I previously inserted with updated blocks (for a new revision) at the same location and scale. I have always been able to highlight the block in question, then do a Right Mouse and click on "Properties", at which time a table would pop-up with the name, location, scale, etc. of the current block. When I do this now, the "Properties" pop-up is blank but I can get it to display some info by clicking on a "Select Objects" option in the top right corner of the pop-up. The problem is this displays properties of the .dwg file and not the block in question.
The attached .dwg file is what I am working on. The blocks I'm looking to update are the "Drill Chart" and the "PCB shape" above it.
I am guessing some setting has changed but I have no idea what or where. Does anybody have an idea how I can resolve this issue?
Thanks in advance,
Jeff Hollerud
